Message 1 of 13
BT Wi-fi - agreeing T&Cs error message
Hi , looking for some support please.
Tried to login to BT Wifi app, and get an error message stating there's a problem with my BTID.
I can happily use this ID to access MyBT, where I can see an option to agree with BT Wifi T&Cs. I then get a different error. My Broadband has been active around 2 weeks.wifi issue.jpg
Cheers in advance
12 REPLIES 12
Message 2 of 13
Re: BT Wi-fi - agreeing T&Cs error message
Hi, @GROB75 I'm sorry about that, this is a known problem that affects everyone who tries to opt into BT Wifi at the moment. I'll send you a private message so you can get in touch with your details and we'll be happy to help.
Neil
Message 3 of 13
Cheers Neil, have replied to the message now
Message 4 of 13
Hi Graham,
I've had an update from the support guys. Can you try and log on to your MyBT App and then click more (should be in the bottom right of the screen) and let me know if that helps.
Cheers
David
Message 5 of 13
Hi David
Followed the steps, reinstalled the WI-FI app still get a message saying BT ID PROBLEM - "There's something stopping the app using your BT IF"
When I tried to accept the T&Cs again I get the original error message
Cheers
Graham
Message 6 of 13
Thanks for trying that @GROB75 , sorry it's not sorted.
I'll go back to the specialists and will be in touch.
Cheers
David
Message 7 of 13
Hi @GROB75 ,
Can you try the MyBT App and let me know if that works.
Cheers
David
Message 8 of 13
Hi
No issues logging into MY BT via app or website
Message 9 of 13
Thanks again. Can you try this -
Log In
Click the 3 little dots in the bottom right
Click More Apps at the bottom
Then choose BT Wi-fi
Cheers
David
Message 10 of 13
Hi David
I do that, takes me to play store, so I click open, then when I  enter login credentials I get the BT ID error
Cheers
