Message 1 of 6
BT WiFi app not auto connecting to hotspots
I have a OnePlus 8 phone. A few weeks ago I noticed the BT WiFi app wasn't connecting to hotspots and had to manually log in as existing customer. A bit annoying but I've been too busy to investigate. But my mobile data usage has gone through the roof. Today I spent some time trying to resolve the issue and used the "settings" in the app. Here I get told that my device does not support this auto connecting. However, it's not a new phone and had worked previously. Any suggestions?
5 REPLIES 5
Message 2 of 6
Re: BT WiFi app not auto connecting to hotspots
Hi @GEPC welcome to the community and thanks for posting. Some devices include an ‘App Optimisation’ feature which can prevent the BT Wi-fi app from automatically connecting to hotspots. Check your device instruction guides on how disable this feature for the BT wifi app.
Neil
Message 3 of 6
Neil,  Thanks for the pointer. I found the Optimization option (which says it's for the battery usage) and disabled it fo the BT Wifi app.  I'll see how it goes over the next few days,
Message 4 of 6
It seems better, but the BT WiFi App used to run in the background. Maybe once every 4 or 5 weeks It would close but reopening it wasn't too much of a problem. Now I have to leave it open as an app to get the same auto login function! Anyway,  better than it was and data usage back down, so thanks
Message 5 of 6
@GEPC I'm glad it's better and more importantly your data usage has reduced. Were there any recent updates to your mobile firmware?
Neil
Message 6 of 6
Yeo! Update about 5 weeks ago... Could be that!
If it's a bug, I hope they fix it next time.
Thanks for your help.
