Message 11 of 17
Re: BT in-app Speed Test crashes router at 68% everytime
Interesting I have the same issue thought it was just me!
Message 12 of 17
Same here
Message 13 of 17
Same here my bt speed app test not worked for ages and I ended up with a new router , still did not work . Think it’s an app problem ,
And yes I tried everything , speed test on other sites works fine , so just annoying really for me
Message 14 of 17
Yep 68% and crash, guarantee 150 but less than 45, seems whenever there is a chance to force them to look at my full fibre it dies?
seems to be a trend, will try the full reset after work but as mentioned here “it’s likely to be ok this evening “
Message 15 of 17
Mine working fine. BT Smart Hub 2 on FTTP.
Message 16 of 17
Update
well it turned out before I Factory Reset it I had a nose around and found that ALL wifi device on 2.4ghz and nothing on 5ghz!
Ethernet was usable but frankly I wasnt impressed and no number of restarts fixed it so I Reset the router with a full 60 seconds before it changed colour from blue to green
after the slow count to 60 I released the pencil in the Factory Reset hole and it came back and all seem to be as it should be again.
can I suggest that any ethernet connection other than the WAN link for full fibre be disconnected during the reset
Message 17 of 17
I have also been experiencing exactly the same issue.
