Message 11 of 14
Re: BTWifi connection
I find the BTApp allows me to roam and use BTwifi without having to log in each time.
Message 12 of 14
Yep, that's the point of the app, it just automates the login process.
Message 13 of 14
Which is why I recommended it for the OP.
Message 14 of 14
Exactly. It works for me that way too but unfortunately the app works only on the iPad not a MacBook and it’s the latter that I want to be able to use with the same sort of reliability.
