Message 11 of 19
Re: Can’t connect to wi fi while out
Hi yes I have tried entering my details when the option comes up but it won’t except them and I have tried log in details many times so know I am using the correct details it just won’t let me connect
Message 12 of 19
Re: Bt profile
With an iPhone you should be connecting to BTWIFI-X. which is intended for apple devices
Message 13 of 19
Re: Bt profile
Ok I will try that again next time I am out but think I have tried both ways but will let you know thanks
Message 14 of 19
Re: Bt profile
As we keep saying, there is no need to wait until you are out and about, your own hub transmits the BT WiFi X signal, just try connecting to that.
Message 15 of 19
Re: Bt profile
Did you try what was posted in message 6 of the first thread that you started about your problem?
Solved: Re: Wi fi hotspot - BT Community
Message 16 of 19
Hi  I  went off my bt home hub and chose bt wi fi x then went back into the phone and it connected straight away like you said , it’s just that it says unsecured network now but it shows that it works so thank you to everyone that helped 😊
just got to find why it won’t verify now on connection profile even though it’s been installed but thanks again
Message 17 of 19
Re: Bt profile
Hi I did and it worked  at home and will be in town tomorrow and hopefully it’ll connect now thanks
Message 18 of 19
Re: Bt profile
Hi
yes I did what I did was to swop my bt wi fi password for the bt wi fi -x  to try and it connected to it so now I’ll try today while I am out
Message 19 of 19
Re: Bt profile
Your BT WiFi username and password are only relevant when connected to a BT WiFi signal. They are not relevant when attempting to connect to other public WiFi signals from hotels etc.
