Message 11 of 20
Re: Can’t disable web protection
I want the option to turn it off and on
Message 12 of 20
Hey @Gazzab1978.
I've just given this a test myself, and via my browser it's definitely giving me the option to switch on, then switch off again.
It definitely said 'this will be switched off within 2 hours' on the second occasion too.
Have you tried using a different device and browser to request this? If you don't have the option to do so, logging in from a private browsing window with no cached data can be worth trying too.
Peter
Message 13 of 20
Yes ive tried that as well still no joy
Message 14 of 20
I still don't understand your need to be turning the WiFi on and off.  I also think you may be misunderstanding the role of BT Web protect - it's not an adult filter, it's a malicious site filter which not all 18+ sites are!
You do have the options for parental controls elsewhere in the router security, but these don't make for great babysitters!
I only learn by making mistakes and owning up to them - boy do I learn a lot!
Message 15 of 20
The turning off the wifi and using the data on my device i don't have any restrictions of any websites as soon as I turn my WiFi back on it will block 18+ sites ect the bt app wont turn off web protect and parental controls or even turn them on
Does that make sense to you
Message 16 of 20
How do you know it is Web Protect blocking the sites?
Has Web Protect informed you that it has blocked the sites?
Do you have any browser addons or any antivirus/ anti malware installed that could be blocking the sites?
Message 17 of 20
No anti virus installed
At top of the page it will say safe search is locked with this message when i turn the WiFi off I can change the settings and when the WiFi is on it will be locked
Message 18 of 20
That's Google's Safe Search, built into the Google browser, it has nothing to do with the BT app/web setting!!!!
Message 19 of 20
As has been pointed out Googles  "Safe Search" is not the named product  "BT WebProtect" and as such it has nothing to do with BT.
If you do an Internet search of "Safe Search" you will find out how to turn it on and off.
Message 20 of 20
I understand what your saying i have googled it ive been through goggle settings ect for a while now
I only can turn it off when my device isn't connected to the WiFi
As soon as I connect my device to the WiFi even when I turned it off through 5g ect it will lock safesearch and I cant change it and it gives me that message what I posted above
I think it's something I'm just going to have to live with like someone said in earlier post it's not a bad thing is it
