Message 1 of 4
Deleting Parental Controls
Parental Controls - suggestions how to delete?
I am temporarily using BT Mini Hub (after telegraph pole knocked down outside bringing all the lines down, and will not be normal broadband service for several more weeks at least). Parental Controls are set by default on the Min Hub.
BT website deletion instructions do not work and their tech team unable to find the way through to the appropriate area to make the amendment
Any suggestions much appreciated
3 REPLIES 3
Message 2 of 4
Re: Deleting Parental Controls
Hi @Southbucks, welcome to the forum, and thanks for your post.
I've had a look around and hopefully, this information I found on the Quick Start guide helps you.
We’ve set light parental controls You can change these by holding the power button down for ten seconds and it will reboot.
Cheers
John
Message 3 of 4
Thanks John. However, I have already tried this BT instruction booklet route; it does not work and, as i sais, the BT Tech people couldn`t figure out either how to lift parental controls.
Message 4 of 4
@Southbucks I'm sorry that isn't working for you. I'll send you a private message in a moment so you can send over your details and we'll be happy to help you get the parental controls removed.
Neil
