Message 1 of 3
WiFi access
How can I restrict access to my BT WIFI (teenager problems !!) ? When I log into the BT app (in BT WiFi Controls) it asks me to download the app - the same via a PC - yet I'm already in the app ? I spoke to BT and was told to go in via the Smart HUB manager, yet when I do I'm told "Access controls are now managed using the My BT app" !!
2 REPLIES 2
Message 2 of 3
Re: WiFi access
are you trying to restrict access to BTWIFI as you posted or is it actually the wifi from your hub with hub SSID?
Message 3 of 3
Re: WiFi access
See links about Parental Controls although if you are trying to stop computer savy teenagers you will find pushing water uphill an easier task.
How to keep your family safe online with BT Parental Controls and the different blocking categories ...
Parental controls | BT Help
