Message 1 of 4
Error Code205
How do I fix the Error Code LP205.
I keep getting this code on my Android tablet when attempting to watch BT Sport.
The code says I am OUTSIDE the UK but at no time am I out of the UK.
Being an "octogenarian" I am not fully conversant with modern technology.
3 REPLIES 3
Message 2 of 4
Re: Error Code205
Hi, @ROY81 welcome to the community and thanks for posting, do you have a VPN activated on your tablet? This could be a feature of your anti-virus software and masks your location thus resulting in the LP205 error.
Neil
Message 3 of 4
Re: Error Code205
Thanks Neil for the reply.
Yes, have turned off, works perfectly.
Easy when you know how 😉
Message 4 of 4
Re: Error Code205
@ROY81 That's great, I'm glad you got it sorted.
Neil
