Message 11 of 14
Re: Fibre speed
Yes I have confirmed this with BT , since the mybt app was updated for me on iOS no speed tester and ther is no way to test connection to your router ip address.
Message 12 of 14
Re: Fibre speed
Been informed by BT it is a big on the last app update.
Message 13 of 14
Re: Fibre speed
Yes they shifted it to mybt app which has been updated and has a bug on speed test under investigation.
Message 14 of 14
Re: Fibre speed
The my bt app speed test when it was working  tested to your personal router and shoes you the speed from exchange to your router from which you can check your stay fast guarantee or mine is 700 mbps,
