Message 1 of 14
Fibre speed
My BT not testing fibre speed
Tags (1)
13 REPLIES 13
Message 2 of 14
Re: Fibre speed
MyBT has been seriously injured due to a bad release update!
Try this beast :  https://speedtest.btwholesale.com/
Message 3 of 14
Re: Fibre speed
The BT openreach  tester will not test my personal  fibre account
Message 4 of 14
Re: Fibre speed
Unfortunately the website test is an end to end test. It doesn’t test just to the hub as the app test used to do.
Message 5 of 14
Re: Fibre speed
As stated the MyBT has been broken due to a bugged release.
Message 6 of 14
Re: Fibre speed
The link posted by @Carlusha  will give you a speed test or you can try fast.com
Message 7 of 14
Re: Fibre speed
Can you advise when the bug will be rectified please?
Message 8 of 14
Re: Fibre speed
@downlands
This is a customer help customer and your post does not go to BT so you could  try CS 03301234150 but I doubt they will have any idea of timescale of fix
Message 9 of 14
Re: Fibre speed
You are assuming it’s a bug, and not a deliberate degradation.
Message 10 of 14
Re: Fibre speed
It is a bug. The Moderators have confirmed this and the release is under investigation. You can find this on other topics.
