Message 1 of 22
BT WiFi app?
Hi everyone, I note the BT WiFi service has moved across to EE WiFi. The BT WiFi website has a link to their app that I used to use on my old iPhone, but the app is no longer available and EE don’t seem to have a replacement.
How does automatic login work for EE WiFi if there’s no app available with the profile to install?
Cheers.
21 REPLIES 21
Message 2 of 22
Re: BT WiFi app?
Message 3 of 22
Re: BT WiFi app?
I have already read this document and it mentions nothing regarding the app, even though it is shown on the BT website?
Message 4 of 22
Re: BT WiFi app?
I'm still using the BT wi-fi app, hasn't let me down yet.
Message 5 of 22
Re: BT WiFi app?
Does this help? It seems things have changed around for BT WiFi as part of the changeover to EE WiFi  https://community.bt.com/t5/Broadband-Extras-Apps-from-BT/EE-WiFi-Auto-on-SH2-in-place-of-BTWifi-X/t...
Message 6 of 22
Re: BT WiFi app?
It will disappear when you update the os
Message 7 of 22
Re: BT WiFi app?
The App has been discontinued, and you will have to log in every time with EE. What a farce! BT’s customary treatment of its customers again!
Message 8 of 22
Re: BT WiFi app?
Just a joke. Sat in a village connected to an Ee, repeatedly having to login when the wifi drops very annoying.
Message 9 of 22
Re: BT WiFi app?
"How does automatic login work for EE WiFi if there’s no app available with the profile to install?"
It doesn't - you have to login to your BT account every time you want to connect to an EE hotspot. It's called progress in BT/EE speak!
Message 10 of 22
Re: BT WiFi app?
No good for iOS users but if you are on EE for mobile and using Android, automatic login to EE WIFI-X still appears to work if you authenticate using your SIM.
Tags (1)
