Hi,
I cant login to my my bt app, or even through the website. I already reset my password, tried to login with incognito mode,from browser, delete and reinstall the app, from my own mobile network, etc... but still getting the same error message: "we couldnt sign you in SAF token processing failed..."
Im not able to see my bill, or anything from my account.
Tried to call, or chat, but couldnt contact.
What am I supposed to do?
Solved! Go to Solution.
Hi,
I cant login to my my bt app, or even through the website. I already reset my password, tried to login with incognito mode, but still getting the same error message: "we couldnt sign you in SAF token processing failed..."
Hi @magdesz
Welcome to the community.
Thank you for coming back and explaining your solution, I am pleased it's all resolved now.
Ritu
I have the same problem - can you remember which number you contacted? I had a previous account under my old hotmail email account, where my new account which is affiliated with my gmail account refuses to work. I guess that if BT can delete my old account then it will recognise my new account fingers crossed!
Thanks for coming to the community.
Sorry to hear you're having the same issue.
I'd recommend getting in touch with our support team so they can take a closer look at your BT IDs and investigate what's happening.
You can find the available contact options on our Contact BT Help page.
Debbie
I used the chat, had to wait like 30 mins in the queue, but they solved my problem, so definitely worth it.
Have now contacted BT via the messenger service, where I am pleased to say that the issue has now been resolved, which is a major relief!
Thanks for letting us know that our messenger guides were able to solve this.
I really appreciate you sharing your experience.
Chris S
