Message 2 of 9
MyBT app
Hi,
I cant login to my my bt app, or even through the website. I already reset my password, tried to login with incognito mode,from browser, delete and reinstall the app, from my own mobile network, etc... but still getting the same error message: "we couldnt sign you in SAF token processing failed..."
Im not able to see my bill, or anything from my account.
Tried to call, or chat, but couldnt contact.
What am I supposed to do?
8 REPLIES 8
Message 1 of 9
Hi,
I cant login to my my bt app, or even through the website. I already reset my password, tried to login with incognito mode, but still getting the same error message: "we couldnt sign you in SAF token processing failed..."
Message 3 of 9
Re: MyBT app
Just a quick heads up, in case of anyone having the same problem, and reading this message: after long waiting time, I could speak to a human on chat. Apparently there was a glitch in my account login, so he deleted my bt id, and "recreated". So its all good and working!
Message 4 of 9
Re: MyBT app
Hi @magdesz
Welcome to the community.
Thank you for coming back and explaining your solution, I am pleased it's all resolved now.
Ritu
Message 5 of 9
Re: MyBT app
I have the same problem - can you remember which number you contacted? I had a previous account under my old hotmail email account, where my new account which is affiliated with my gmail account refuses to work. I guess that if BT can delete my old account then it will recognise my new account fingers crossed!
Message 6 of 9
Re: MyBT app
Hi @benwilliscroft81.
Thanks for coming to the community.
Sorry to hear you're having the same issue.
I'd recommend getting in touch with our support team so they can take a closer look at your BT IDs and investigate what's happening.
You can find the available contact options on our Contact BT Help page.
Debbie
Message 7 of 9
Re: MyBT app
I used the chat, had to wait like 30 mins in the queue,  but they solved my problem, so definitely worth it.
Message 8 of 9
Re: MyBT app
Have now contacted BT via the messenger service, where I am pleased to say that the issue has now been resolved, which is a major relief!
Message 9 of 9
Re: MyBT app
Hi @benwilliscroft81,
Thanks for letting us know that our messenger guides were able to solve this.
I really appreciate you sharing your experience.
Chris S
