Message 1 of 3
Norton Anti virus (fromBT) on 2nd PC.
At the moment I have Norton anti virus from BT on my desktop (windows 10), I am about to get another PC (windows 11). How do I go about installing it on the new PC as I believe you are able to use it on 2 PCs.
2 REPLIES 2
Message 2 of 3
Re: Norton Anti virus (fromBT) on 2nd PC.
The same way as you did it on your first PC, from MyBT
Message 3 of 3
Thank you, it has been so long that I could not remember how I first set it up. I see now that it is in security and gives an option to add another device.
