Message 11 of 12
Re: Norton Security
If you don't use Express VPN and it sounds like you don't, just uninstall it.
See link if you are not sure how to do that.
https://www.expressvpn.com/support/troubleshooting/uninstall-expressvpn-app/?srsltid=AfmBOopGl1UOKVC...
Message 12 of 12
Re: Norton Security
Thanks. I've now completed to my satisfaction with the help of ExpressNVP, so the case is now closed. Thank  you for your suggestions, I really appreciate it.
