Message 1 of 7
Norton anti virus new laptop
Trying to load Norton on my new laptop and get the following message;
An unexpected system error occurred and we can’t display your information at this time. Please try again later.
Request Id : 800023d1-0001-9100-b63f-84710c7967bb
Any suggestions on how to load Norton?
David
6 REPLIES 6
Anonymous
Not applicable
Message 2 of 7
Re: Norton anti virus new laptop
Not a direct answer but I haven't run any anti-virus bar Windows Defender for probably 12 years or so. Number of viruses contracted in that time? - 0.
Message 3 of 7
Hi @db13366 and welcome back.
Good to see you after so long. Sorry you're having problems loading the Norton. Take a look at What is BT Virus Protect and how do I get it? | BT Help for help and advice with this.
Cheers
David
Message 4 of 7
Thanks. I am already using Norton on another laptop and have upgraded my wifes. I cant load it on the new one just get an error message. The link wasnt of use.
Anonymous
Not applicable
Message 5 of 7
Have you maybe run out of licences? Starting point is two I believe.
Message 6 of 7
Thanks. I assume I will need to remove it from my old laptop and then try again.
Anonymous
Not applicable
Message 7 of 7
Depends how many licences your package entitles you to. Is it listed on your original order confirmation?
Even if you uninstall, I don't know if other action is required to release the licence. You really need input from someone that's used it on multiple devices.
