Message 1 of 2
Norton download
I'm having trouble installing Norton security on my new laptop. Apparently because I have arm processers I have to download the app from the store but I don't have a Norton account so unable to activate it. What do I do?
Tags (1)
1 REPLY 1
Message 2 of 2
Re: Norton download
Hi @Steve66,
As per the Norton website here unfortunately BT Virus Protect is not compatible with Arm processor devices so it wont be possible to set it up on that laptop, though you should still be able to set it up to protect other compatible devices you may have. System Requirements to install and set up BT Virus Protect powered by Norton
Alex
