Message 1 of 6
Unable to down load new Norton anti virous onto tablet. OK on laptop.checked up dates on chrome.
5 REPLIES 5
Message 2 of 6
Re: Norton
HI @Tony667, welcome to the forum, and thanks for posting.
Sorry that you're having trouble setting up Norton.
Have you been able to install Norton ok on other devices?
Is the tablet running on Android 8.0 or a later version?
Cheers
John
Message 3 of 6
Re: Norton
Running on Android version 5.1.1
Message 4 of 6
Re: Norton
Norton only works on Android 8.0 or later so you will not be able to install it on your device.
Important updates to your virus and password prote... - BT Community
Message 5 of 6
Re: Norton
Can i update current tablet ?
Message 6 of 6
Re: Norton
No.
