Message 1 of 2
Problem using BT Parental Controls
Hi David,
I'm having the same issue - there is no Manage my Extras button and the link to parental controls doesn't work - and the instructions on how to set it up haven't been updated since the BT logo was updated years ago:
https://www.bt.com/help/security/how-to-keep-your-family-safe-online-with-bt-parental-controls-an#se...
Please can you help?
1 REPLY 1
Message 2 of 2
Re: Problem using BT Parental Controls
Hi @RWLondon1
Welcome and thanks for your post!  I have moved your post to start your own discussion as the thread you posted on has already been marked as solved.
I am sorry for the problems you're having with Parental Controls.  I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Thanks,
Robbie
