Message 1 of 4
Remove devices from MyBT app
When logging into the MyBT app from my mobile, despite setting it to use fingerprint login it regularly reverts to username and password, which then sends me an 8 digit pin to enter. After entering this the app then presents me with a screen asking if this is my device and if it is trusted to give it a name.
The name field is filled in automatically but it gets rejected as the device name is already present so I have to give it a new name. Apparently I currently have 7 devices registered now, despite only using 1 mobile and 1 laptop to access my account.
I did call BT to discuss and was told it was because I used 2SA to login, despite it not being set up (according to the app) as I set it to use fingerprint. When I explained I hadn't set up 2SA I was cut off, very rude.
How can I delete most of the devices that have been registered by the app as I can't find the option to view or delete devices?
3 REPLIES 3
Message 2 of 4
Re: Remove devices from MyBT app
Log on to MyBT from a laptop or PC
Click on Your Details (Top Left (ish))
Confirm or amend your details as necessary
Edit 2 Factor Authentication or 2 step Authentication (can't remember which offhand
Message 3 of 4
Great, that had the info I needed, and showed more than 7 devices, many thanks.
Message 4 of 4
Followed advice you were given, but, no option to delete?
Ian Roe
