Message 1 of 9
norton
Trying to swop over to norton but getting virus scan failed if anyone has had the same
8 REPLIES 8
Message 2 of 9
Re: norton
What device are you using?
Have you uninstalled McAfee and managed to install Norton?
Message 3 of 9
Re: norton
Thank you for the reply
Lenovo windows 10
mcafee is still installed
Message 4 of 9
Re: norton
You will need to uninstall McAfee before installing Norton.
https://community.bt.com/t5/Broadband-Extras-Apps-from-BT/Important-updates-to-your-virus-and-passwo...
Message 5 of 9
Re: norton
Will try that thank you
Message 6 of 9
Re: norton
I also having same issue Lenovo windows 10 and have uninstalled Mcaffee, it's made no difference I still can't download
Message 7 of 9
Re: norton
Thank you. Yes I have heard the same hopefully BT will get it sorted.
Message 8 of 9
Re: norton
@Nick64 @Johntina93
Did you use the NcAfee removal tool as it sounds like you still have remnants of McAfee still on your device like many other posts
Message 9 of 9
Re: norton
Thank you.
