Message 11 of 11
Re: BT TV Pro box sometimes fails to get current time
@HazelThomaswrote:
May I ask how you were able to get BT TV functioning with Pfsense? I haven't had much success.
I don't subscribe to BT TV so I can't help - there are some posts on Reddit regarding configuring pfSense with BT TV multicast - you want to search for IGMP settings and you will need to enable IGMP snooping on any switches between the pfSense router and your BT TV box.
____________________________________________
BT FTTP 500/75 + pfSense + 4 x UniFi Wifi 6 Pro
