Message 1 of 7
BT TV Pro box
Can/does the BT TV Pro box use wireless & wired connections simultaneously where both are available from the Smart Hub ?
6 REPLIES 6
Message 2 of 7
Re: BT TV Pro box
Hi @nigelwe
No. It's either WiFi or ethernet. As both deliver sufficient bandwidth for IPTV what would be the use case for having both?
MikeAlanR
Message 3 of 7
Re: BT TV Pro box
Thanks for coming back.  There don't appear to be any controls that would allow me to switch the wireless off in favour off a better/stable wired connection straight from the BT Hub..... unless you know different ?
A lot of the Googling I've done comes back and says that a wired connection is always better than a wireless connection, but no one has said how to turn off the wireless !
Anonymous
Not applicable
Message 4 of 7
Re: BT TV Pro box
There is no need to switch off WiFi. If you don't set up a wireless connection in the first place, then none will exist. If you have then it will be disabled as soon as you plug in the ethernet cable.
Message 5 of 7
Re: BT TV Pro box
Hi @nigelwe
As @Anonymous  Indicates you don't have to set up WiFi. However I'm sure there is a forget network option too in the network screen. (Not near box to check).
In any event the box is 'intelligent' enough to use eithernet over WiFi when a cable is plugged in.
MikeAlanR
Message 6 of 7
Re: BT TV Pro box
Many thanks 👍
Message 7 of 7
Re: BT TV Pro box
@mikealanr
Is there a ‘not’ missing there? 😛
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
