Message 1 of 18
Hi folks,
Newbie asking a question , just signed up to the £12 per month Entertainment package with BT and was under the impression that the National Geographic Channel was one of the channels included free within the package. I don’t seem to be able to get it, am I wrong with my thinking it should be included?
Thanks to you all for helping
17 REPLIES 17
Message 2 of 18
Re: BT TV
Hi @Jelugs
It's not available I'm afraid, I think it was removed over a year ago.
Message 3 of 18
Re: BT TV
Hi @Jelugs
It is now part of the Disney and on their app.
Stew
Message 4 of 18
Re: BT TV
Thanks so much
eric
Message 5 of 18
Re: BT TV
Thanks so much
Regards
Message 6 of 18
Re: BT TV
Just to add that Disney plus in the UK don't add live streams of their channels it is just that the national geographic content is available to watch like you would watch content on Netflix etc.
Message 7 of 18
Re: BT TV
Thanks for that, will give it a try and see how i get on.
best wishes
eric
Message 8 of 18
Re: BT TV
Think your getting it mixed up with the discovery channel
Message 9 of 18
Re: BT TV
Thanks for your input but no it was the National Geographic
regards
Message 10 of 18
Re: BT TV
From 1st November, I believe you will be able to sign up to Disney plus with adverts subscription for £5 per month, which is cheaper than the standard £7 a month just now, if you can hold off and don't mind adverts
