Message 1 of 11
BT box pro remote control
 When I press the back button on the remote the bt symbol at the top displays  constant blue for over 10 seconds.       This happens especially with the youtube app . Therefore when pressed it exits out of youtube altogether. Could this be    an issue with the box or remote? No button is sticking on the remote. Thanks
10 REPLIES 10
Message 2 of 11
Re: BT box pro remote control
Hi @northwest,
Thanks for visiting the BT Community
Have you tried giving the remote a reset to see if that resolves it? As it does sound like something with the remote since the light is on and the command is being constantly given to the box.
If that doesnt work I would recommend getting in touch with our TV tech team and they will be able to help further.
Alex
Message 3 of 11
is there a time on screen time out
Message 4 of 11
Hi seems to be solved by a reset. Thanks
Message 5 of 11
Spoke too soon. The remote now has other issues if I remove the batteries then replace the bt symbol stays a steady blue for 30 seconds or more. The back button issue is back. If I perform a remote reset only pressing the home and 9 buttons work ie symbol flashes 3 times then I cant do anything including pressing home and 7 to pair the remote. Eventually it will pair but is gltichy. I originally got the box pro with remote  form BT but got changed over to EE because I wanted sport etc I was told I had to do it that way. Which could be at fault remote or box? Do I need a new one of either? Trying to talk to a human via EE is impossible.  Thanks
Message 6 of 11
Your best option is to click the getting in touch link that Alex shared. Talking to a human is very easy, but you may need to wait for a little bit.
Message 7 of 11
Yes tried that.  It stated theres a fault in the area and will be sorted! However how would that affect a remote control? No option to talk to someone. Cheers
Message 8 of 11
Please listen carefully to the options. It should never prevent you speaking to someone. Those announcements are just to prevent you waiting on the line about known issues.
Message 9 of 11
When I choose fault it defaults to theres a fault in your area please hang up.
Message 10 of 11
Choose a different option. I don't know the current options, but try technical assistance rather than fault. Or even accounts and billing - it's just a replacement remote needed, so pretty much any department can handle it.
