Message 1 of 3
Channels keep going off
Hi does anyone else's channels keep going off and on please I've checked all connections they fine
2 REPLIES 2
Message 2 of 3
Re: Channels keep going off
@Needadvice72
What exactly do you mean?
Are the channels breaking up?
Is it subscription channels or the standard Freeview one like BBC & ITV?
Can you go into Settings -> TV Signal Quality for any of the channels that have a problem. For Quality 100% is the target , for Strength the ideal range is 80-92%. If you see 95-100% for signal strength then that would be the problem most likely.
Message 3 of 3
Yes all the channels keep flickering on and off on my bt box i have reset the boxes and checked all connections
