Message 1 of 3
Ethernet Cable on BT TV Box
My yellow ethernet cable connected to BT TV Box is flashing yellow all time, on stand by and when connected.
Is this a problem ? Tks for any responses.
2 REPLIES 2
Message 2 of 3
Re: Ethernet Cable on BT TV Box
@tuanton
Obviously not the cable itself but the port and yellow shows it's a 100Mb connection and the flashing is normal as that's data to & from the router.
So nothing to be concerned about.
Message 3 of 3
Tks for prompt response.
