Message 1 of 4
How to watch live TV and now TV on eetv mobile app
I've just come over from Sky after nearly 20 years. Having skygo has been a life saver at times. Now I'm with BT/EE I'd like to be able to do the same with the EE TV mobile app, including watching now TV. Looking for some advice as to how I go about doing it.
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: How to watch live TV and now TV on eetv mobile app
You can’t.
BT/EE do not have the same level of joined up mobile offering as Sky Go.
Essentially you have to choose the right app for the job rather than just having one. The NOW app for NOW content, discovery+ for TNT Sports, the EE TV app for whatever is left (I can’t remember to be honest, haven’t used it for years).
On the plus side, using dedicated apps does provide better picture quality than Sky Go, but whether or not that matters is personal choice.
Message 3 of 4
Thanks for the reply
I have NOW TV as got the full package, but how do I find out sign in ? As it's come with the package. I have discovery plus, iPlayer, netflix etc. I've downloaded now TV app, but don't know how to link it with my BT/EE TV account.
Message 4 of 4
@Noddy71 Your NOW account should have been created as part of the signing up process. On the EETV box on the NOW app it will sign in automatically as it will detect your broadband line from the box. You can check which email you used by going into the NOW app on the EETV box and going into settings ( the small cog in the top right hand corner). Your email should be in the bottom left hand corner on the next page. Hopefully this will remind you of your password. If the NOW app on the EETV box is not working this would suggest that your account has not been set up properly and would require further investigation.
