Message 1 of 2
Pairing a 3rd party bluetooth remote to Box pro
Hi,
I'm guessing I already know the answer to this but, was just wondering if anybody has successfully paired a 3rd party bluetooth remote to the Box Pro and how they did it?
The box pro has no pairing mode so I'm guessing it can't be done and the only way to get one remote to control all my A/V equipment is via IR
If you know a workaround or way to pair a 3rd party bluetooth remote to the box pro please let me know?
1 REPLY 1
Message 2 of 2
Re: Pairing a 3rd party bluetooth remote to Box pro
Hi there @Spurs1
Thanks for coming back to the community.
Could you try the steps in the Reset and pair your EE TV Box Pro remote page to see if this works?
Thanks.
Leanne.
