Message 1 of 2
TV Box Pro no menu overlay
Hi all, I’ve had a recurring issue where sometimes there is no menu overlay appearing on my TV Box Pro. I am able to watch live TV, and if, for example, I press “101” it’ll tune to BBC One, but the numbers don’t appear on screen. I can press the guide button and nothing pops up but if I use the buttons to select a new channel as if the menus did pop up, it’ll tune to the new channel.
It’s kind of hard to explain without seeing it, but I have a video recording of it if there’s a way for me to post it.
1 REPLY 1
Message 2 of 2
Re: TV Box Pro no menu overlay
give it a reboot, then go onto settings and then software info.
Do a software update from there. if it says you are up-to-date then I would suggest trying the factory reset option.
