Message 1 of 15
Youview DTR T2100 box froze, and now won't power on
I came home and my DTR T2100 was on with a blue light showing, but the TV wasn't receiving a signal from it and it didn't respond to the remote or any button presses.
I switched it off with the power button, but now when I try to switch it back on there is no power - nothing happens at all.
The plugs on my other 12v power packs are too big to fit so I can't confirm if it's the power pack at fault (although I suspect not since it was working until I switched it off).
Any thoughts as to what (else) the cause/solution might be?
14 REPLIES 14
Message 2 of 15
Re: Youview DTR T2100 box froze, and now won't power on
Most likely a faulty hard drive.
Switch it off again for a few seconds and power it up in a quite room with your ear to it, listen for any repetitive clicking noises or the persistent sound of a small electric motor repeatedly starting up and shutting down, either one  confirms a faulty drive
Message 3 of 15
Cheers for the reply but it won't power up at all. I've tried with a new plug so it's not that.
Do you think it could repaired (or the disk transferred to another box)?
I don't want to lose all my recordings if I can help it. 😪
Worth me opening it up to see if I can see anything?
Message 4 of 15
The disk spin up is part of the box start up process, if the disk fails then the box won't start. Listen for the noises I described in my earlier post,
Message 5 of 15
There's no noise at all.  No power lights come on - makes me think it could be something other than just the disk.
I guess based on what you say the box wouldn't work as a basic Freeview tuner if the disk has failed?
Message 6 of 15
No.
BT will replace it if you're in contract but if not then you could do worse than look at Gumtree or EBay
Message 7 of 15
Facebook Marketplace is another source for cheap T2100s.
If you Google "DTR T2100 hdd upgrade" you'll find instructions for accessing the HDD. But there's a suggestion that transferring a disk to another box might cause it to be initialised/wiped. But as you currently don't have access anyway I guess there's nothing to lose by trying. It would also give you another PSU to try first.
Message 8 of 15
There's some very knowledgable guys on the Hummy.tv site & as it's a Humax manufactured box, you may find assistance there.
Message 9 of 15
Cheers!
Message 10 of 15
I tried a new power pack and no effect.  I put in a new HDD (with the old power pack) and still no power.  Any ideas what might be wrong?
