Message 11 of 14
Re: Youview DTR T2100 box froze, and now won't power on
If there's no activity at all then it could be something as simple as a faulty rocker switch on the back.
Message 12 of 14
Cheers. That would certainly make sense - it was the last thing I touched (to switch it off for a reboot) before it stopped working.
Do you think that could be fixed or replaced?
Message 13 of 14
That's one of those Yes & No questions I'm Afraid.
Yes it is easy enough to change if you have the necessary skills but finding a suitable replacement might not be so easy.
If you're under contract then BT will replace the box free of charge.
Message 14 of 14
The power supply units are known to fail, so its worth trying a suitable spare if you have one.
