Message 1 of 4
Error 553 0n email, how to fix ?
How to fix error 553 & what causes it.
3 REPLIES 3
Message 2 of 4
Re: Error 553 0n email, how to fix ?
Hi @GardenofEngland, welcome to the forum and thanks for your post.
Are you using a VPN? If so disconnect it and try sending the email again.
If you don't use a VPN try disconnecting your BT Hub for 15 mins and reconnecting it. It should result in you getting a different IP address and that may resolve the issue.
Let us know how you get on.
Cheers
John
Message 3 of 4
Well, problem seems to have fixed itself, logged out for a few hours, connected again and everything ok.
Never happened before, so lets hope it doesn't happen again.
Regards.
Message 4 of 4
Thank you for posting back to update the thread. If the issue reoccurs please post back.
Thanks,
Paddy
