Message 1 of 8
Error code 100006
when I type in the correct email address, the error code 100006 comes up
7 REPLIES 7
Message 2 of 8
Re: Error code 100006
Hi @LawrenceFairweather and welcome.
Thanks for posting about your email issue. Can you give us some more details? What are you typing the address into? Are you looging in to your BTID? Are you using a mail client? Are you seeing this on all devices?
Cheers
David
Message 3 of 8
I was typing the address into the BT email Compose To: box. The address is 'parkingeye.co.uk/appeal' . When I had completed the email, I clicked the 'Send' button and the error code appeared!
Message 4 of 8
Are you using a PC or a MAC? this appears to be quite a common error on MACS.
Fix Mac Error Code 100006 (softwaretested.com)
Message 5 of 8
That isn't an email address, it's a website
Message 6 of 8
Using an HP desk top about 3 -4 years old. Window11.
Message 7 of 8
Thanks for getting back @LawrenceFairweather
Your devices are irrevelant in this instance. You're trying to email a web site. I've had a look and there is no email contact for that but you'll find contact details at Contact us - Parkingeye
Cheers
David
Message 8 of 8
Thank you so much. Should have asked my Grandson!!!
