Message 11 of 17
Re: Height of screen display
When you hit reply you should get a new screen with a box to type into. Above that box is a line of icons one of which is a camera (in about the middle) if you select that you should be able to inset your screenshot.
Message 12 of 17
Thanks.
In case it helps here is the screenshot.
Patrick
Message 13 of 17
Your email address is visible in the screenshot, I suggest you edit the screenshot and repost before you get more spam than you can cope with.
Message 14 of 17
Can I delete the post?
Message 15 of 17
Yes, select edit from the 3 dots in the right hand corner and delete the content of your post. You can't actually delete the post, just the content.
Message 16 of 17
Thanks.  I have replaced the image in the earlier post.
Patrick
Message 17 of 17
I now see that the image hasn't appeared, so here it is.
Patrick
