Message 1 of 3
No images BTMail
HI, I no longer can see any images in my emails (BT Mail) . Just a box where they should be.   This is since the new BT Mail format. I'm using through chrome and checked security but this all seams normal and standard.
2 REPLIES 2
Message 2 of 3
Re: No images BTMail
If you check the email forum you will see a few threads regarding the "New" BTMail interface which has been having some issues and problems and that the problem you have posted about has been asked and answered a few times.
See links
Webmail migration update - BT Community
BT Webmail Work Arounds. - BT Community
BT Webmail Feedback - BT Community
Message 3 of 3
Hi
Thanks for that all sorted.
I did do a search but the only relevent post was about the privacy setting in the search engine you where using.
Anyway thanks again.
