Message 11 of 16
Re: Unread emails
I have no idea why your webmail is not showing that on all the browsers. It would tend to indicate an issue with your email account.
I have notified the moderators of the forum about your problem. Once they have read this they may be able to help. They will advise you by posting on this thread.
Message 12 of 16
Re: Unread emails
@mar5kmozart I think you're on the older version of webmail. If you change view to right, do you get the two sorting icons beside your search bar?
Neil
Message 13 of 16
Re: Unread emails
I do!
Message 14 of 16
Re: Unread emails
Ah.. it would appear you have not been migrated yet.
From memory to sort the emails out just click on the arrow you see.
Message 15 of 16
Re: Unread emails
OK - I've got a work-round until I'm migrated. Thanks for your help
Message 16 of 16
Re: Unread emails
@mar5kmozart I'm glad you got sorted
Neil
