Message 1 of 6
Webmail not working?
Hi, my email has just stopped working on my PC - where I use webmail via the Chrome browser. It won't work using the EDGE browser either. It is still working on my iPhone.
Any ideas?
TIA,
Sue
5 REPLIES 5
Message 2 of 6
Re: Webmail not working?
Yes its not working on anything using a browser see me comment in similar vain just before yours in the list.
its probably the main email browser tools rather than the offline tools that would be used by your mobile versions that are really sucking the data from below the webmail browser versions. Since its been struggling for few hours now and getting progressive worse i'd assume they are onto it but are not able to stabilise it.
Message 3 of 6
Ah, thank you, your post landed while I was typing mine (which took me a while as I was experimenting with EDGE at the same time)!
Seems to have sprung back to life now, so fingers crossed that it continues.
Message 4 of 6
Hi Everyone,
Thanks for your posts, we're looking into this and will update you as soon as we can.
Neil
Message 5 of 6
Hi @Sue036 and @unwina,
Thank you for posting. We believe the issue has been fixed. If you're still experiencing any issues, please post back to let me know?
Thanks,
Paddy
Message 6 of 6
It's looking good *fingers crossed* *touching wood*. Thanks!
