Message 1 of 4
synchronise contacts
Hi. I'm using bt mail on Window/Chrome, and the new BT email app on my android phone. The former has its own dedicated contact list; the latter appears to use the phone's contact list.
Is there a way of synchronising the two sets of contacts please?
3 REPLIES 3
Message 2 of 4
Re: synchronise contacts
Hi @freelofty If you click on your email address, go to settings cog and then contacts you can choose between server, your phones contact book or both.
Neil
Message 3 of 4
Brilliant! Thanks NeilO.
Now how do I copy over the device ones to the server?  I have paired the phone to my laptop, tried Bluetooth and USB cable, selected all contacts and exported them to a vcf file, but when importing from BT mail I just get a message saying the file is not valid. Maybe some of those contacts being just numbers without names is causing the problem?  I also tried via CSV file but the same thing.
If not I'll just go through the device contacts and sort them manually.
Many thanks for your help.
Freelofty
Message 4 of 4
@freelofty you might be right about the contacts with no name or email attached to them causing issues.
Neil
