Message 1 of 3
Access to but email using outlook in USA
Unless i run a vpn i cannot access bt email in outlook from Atlanta in USA. This seems to be an issue on all platforms
Keep being told username or password incorrect
2 REPLIES 2
Message 2 of 3
Re: Access to but email using outlook in USA
Hi, Davec, You Should Use the BT Mail Website or app.
Message 3 of 3
@payphoneenthusiast
You are replying to yet another post that is almost a year old.
If you are going to trawl the forum for posts to reply to could you at least check the date that the post was made and also the date that the poster was last on the forum.
In this instance the poster has not been on the forum since October 2024 so it is a strong possibility that the problem has been resolved.
By doing that you will save others from responding to an old resurrected thread.
