Message 1 of 4
BT Mail Desk top icon
How do I set up an icon for BT Email on my desktop?
3 REPLIES 3
Message 2 of 4
Re: BT Mail Desk top icon
Assuming you are using a Windows computer.
Drag the following link onto your computer's desk top. Once it's there right click on it then select "Rename" and name it BTMail or any other name you want.
When you click on it the log on page will open.
Email Login Page (bt.com)
Message 3 of 4
In Windows Explorer, highlight 'Desktop', click on 'New' and select new shortcut. Paste https://home.bt.com/login/loginform?TARGET=$SM$https%3A%2F%2Fsignin1.bt.com%2Fbtmail%2Fsecure%2Femai...
in the form and click 'Next'
Message 4 of 4
Thanks for the help.
