Message 1 of 3
BT email down?
Is bt email down for anyone else?
Earlier it was very slow to load and now im being told password error when i try and login.
is this the else for anyone else I am worried ive been hacked
2 REPLIES 2
Message 2 of 3
Re: BT email down?
No issues with mine.
There may just be a problem with the server you are trying to connect to. If you have a mobile phone try using that when connected to the phone's network not wifi.
Message 3 of 3
Re: BT email down?
Thanks for the reply, it came back about 30 mins after I posted for me.
