Message 1 of 12
BT emails
Emails when deleted off my iPhone are not deleting of my Ipads.
Apple can't find a problem all set up the same
On all devices.
11 REPLIES 11
Message 2 of 12
Re: BT emails
Which email app are you using?
If you delete an email on your iPads does it get deleted from your iPhone?
Is your email app set up as an IMAP account or a POP3 account?
If it is a POP3 account the email is not synchronised with your other devices and as such anything deleted would not be deleted on your other devices.
See link for the correct settings.
 BT Email server settings | BT Help
Message 3 of 12
Re: BT emails
I have 2 ipads  apple checked they are all on IMAP.
However I have deleted emails on both iPad and it deleted on my iPhone. IPhone deletes do not delete on my pads.
Message 4 of 12
Re: BT emails
If I delete emails on the pads it deletes on the iPhone. Delete on iPhone does not delete on my two pads.
I have BT email App and apple mail app.
All on IMAP accounts.
Apple support checked all settings yesterday but don't know the problem. Never had this before.
Message 5 of 12
Re: BT emails
Message 6 of 12
Re: BT emails
Use  BT APP on iPhone and the apple mail.
Have the mail app from Apple.
Have always used these for 3 years with no problem.
I know this duplicate email .
Many Thanks
James
Message 7 of 12
Re: BT emails
I won't give my views about the BTMail app however have you tried uninstalling the BTMail app then reinstalling it?
Message 8 of 12
Re: BT emails
Yes have done this a few times and still the same.
I will give it another go.
Will let you know what happens
Many thanks
James
Message 9 of 12
Re: BT emails
If the re-install does not work try another email app. If that works you will at least know where the problem lies and you can decide which app you wish to continue using.
Message 10 of 12
Re: BT emails
Hi
All email are deleting off off iPhone and pads when I use iPad to delete them but not its use iPhone.  One of the port numbers was wrong on one iPad.
James
