Message 31 of 45
Re: Bt Email font changes
Thank you
I 'm really sorry I said iMac but I should have said it was a MacBook Pro.
Message 32 of 45
Hi,
Here's what my research says:
To change the font in Safari on a MacBook Pro, you can:
  1. Select the Safari menu
  2. Select Preferences
  3. Select Appearance
  4. Under Standard font, select the Select button
  5. Choose your desired font type, size, and colour
  6. Click OK on the Preferences screen
Hope this helps.
Message 33 of 45
Hi
I found appearances but there is nothing under that regarding fonts but thank you for trying to help me.
Message 34 of 45
Hi
I tried in on my wife's Macbook and I got the same result as you! if anyone does figure this out please let us know.
Message 35 of 45
Thank you so much for trying x
Message 36 of 45
Well done, wish I was clever. It was so hard to read my email listings! Not now.
Message 37 of 45
Thanks for everyone's input. Now amended the font used in Chrome
Message 38 of 45
Re: Emails
Hi,
I had the same issue, please try the following:
My browser is Microsoft Edge.
  1. Press: ALT-F on your keyboard
  2. From the RH drop down cascade, choose SETTINGS
  3. From the LH drop down cascade, choose APPEARANCE
  4. 'Customise Appearance 'open drop down to FONTs to change.
Hope this works 4 U folks!
Martin
Message 39 of 45
me too
Message 40 of 45
I'm a bit late to the party here but this is what I found for Windows_11 and Chrome.
Click on Settings / Accessibility / Text Size
Move slider to the right to increase text size (say to 120%).
Apply
Exit Settings.
Note: This increases the text size for all Apps, but at least I can now read my emails.
