Message 11 of 37
Re: Can’t access my emails.
Just tried wife's computer and got in ok, but here's a thing, when I checked the https, it is still opening on the old one which was the one which worked on my computer. When I try and use this link on my laptop, it changes to the new log in https as I watch it load.
Mike.
Message 12 of 37
@westwaleswoman wrote:
I have never worked out how to access apps on my computer but I do use apps on my phone and iPad to open my emails.  Perhaps you can tell me how to on my computer?
Thank you for your suggestions.
@westwaleswoman
An email app on your iMac will work in the same way as it does on your iPhone and iPad.
If there is not already an email app installed on your iMac you need to log onto the Apple Store and select an email app. I don't use Apple so I can not recommend one to you but I do use Bluemail which I believe is available for Macs.
Setting it up is pretty straight forward and it should more or less set its self up.
If you do need any settings they are in this link.
BT Email server settings | BT Help
Message 13 of 37
Just tried the link in one of the first posts and same result. BT logo and dots moving round. Why on earth do the BT engineers break something that was working ok in the first place ?
Mike.
Message 14 of 37
Hi @sparkymike,
Thank you for posting. I'm sorry you're having issues accessing your email on your Laptop.
What Operating System and Browser is your Laptop running?
You said it was working okay on your wife's computer from your earlier post. What operating system and browser is her computer running?
Thanks,
Paddy
Message 15 of 37
Hi sparkymike,
It happens a lot.  Things get “improved” but are not always better than what went before.
I didn’t manage to try a friend’s computer yesterday but will see if I can today.
I saw the reply from the moderator and will answer him re- my computer in a few minutes.
Message 16 of 37
I suspect the problem is just one server in the farm faulty. You can try disconnecting your Hub from line for about half an hour. This should give you a different IP address and possibly a connection to a different server.
Message 17 of 37
Hi PaddyB,
My operating system on my iMac is OSX El Capitan and I use Safari as. Browser.
westwaleswoman
Message 18 of 37
Dear Distinguished Sage,
But my I can access my emails on my iPad and phone which suggests it’s not the server, doesn’t it?
Message 19 of 37
No, because they will probably be accessing a different server.
Message 20 of 37
Hi, wife's compter is windows 10 and browser is Google.
Mine is windows vista and using either Google of Firefox.
Mike
