Message 1 of 5
Can't login to email
I suddenly can't get into emails in Safari on my Mac.  When I put in my password I get sent a passcode which is accepted but then it just reverts repeatedly to the login page.
I have changed my password and cleared the cache but still can't log in.
4 REPLIES 4
Message 2 of 5
Re: Can't login to email
Hi @Karen500 welcome to the community, I'm sorry to see you're experiencing problems logging into your BT email. Are you trying to log in to the BT webmail site www.bt.com/email
Do you experience the same issue on all devices?
Neil
Message 3 of 5
Thanks Neil.
It was just on the Mac and just in Safari.  An overnight system update seems to have solved the problem so was may just a glitch in Safari.  Thanks for the reply
Message 4 of 5
Hi, @Karen500 I'm glad it's sorted.
Neil
Message 5 of 5
I am having the same issue. I have had it on my iphone for several weeks and today I am having the same issue on my laptop. Please advise as I currently can't access my email.
