Message 2 of 21
Can't login to my bt or email
Does anyone have any problems logging in to there email or mybt?
Just keeps saying something went wrong please try again
20 REPLIES 20
Message 1 of 21
email down
Hi cannot log into email at the moment is it down
Message 3 of 21
Re: email down
Thinking it might be. I can't login to mybt either. Also had problems with Broadband being down all weekend during the day
Message 4 of 21
Re: Can't login to my bt or email
I get the same problem if I try and log into MY BT as well.
Have reset my password twice but still cannot get in.
Have tried to call but no options available to get to the correct team.
Message 5 of 21
I have tried a few times. It seems to be happening more and more often now
Message 6 of 21
Same here. Says 'something went wrong. Please try again'
BT - is anyone looking into this? Need to use my email ASAP. Thanks.
Message 7 of 21
Hello I am unable to sign into email either, says something went wrong,
Message 8 of 21
Same here, cannot sign into MYBT, get the "something went wrong" message.
Message 9 of 21
I have the same problem.
Message 10 of 21
It is down at the moment, but I guarantee you these guys will either respond shortly, or it will be sorted.
