Message 11 of 29
Re: Can't send an email
Tim_G,
Hope you get it sorted. I have not heard from BT. I need to contact them in order to resolve the issue. I am using my Gmail account as a work around. No problems with Gmail. It's so frustrating that BT just won't deal with the issue as they are clearly aware it's a general problem.
Message 12 of 29
Do you have a "signature" in your emails. If so try removing it to see if that is the cause.
Message 13 of 29
Thank you but no signature in my particular case.
Message 14 of 29
I have rung BT and reported the issue. It's now logged. Just awaiting a call back.
Message 15 of 29
Re: Can't send an email Error Code 553
No response from BT despite raising a complaint. I have chased them twice now.
This is so frustrating
Tags (1)
Message 16 of 29
No signature.
Only seems to apply when sending mails TO very specific addresses.
Message 17 of 29
Are they on your blocked list, or are they to the same type if email e.g gmail and have you blocked that?
Message 18 of 29
Don't believe I've ever blocked anyone: how would I check?
Message 19 of 29
I certainly receive e-mails from one address (the main one) which the error message won't let me send to.
Message 20 of 29
If you go to settings and click blocked then you'll see the addresses of ones you've marked as spam. Look down the list and hopefully you'll see the one you're having trouble with, and delete it.
