Message 1 of 4
Contact Group
I have a couple of contact groups but when I go in to it to take someone out (they have passed away), I had to go right down the list because they weren't in alphabetical order to find the person.  How do I change that?  Can't find a way anywhere!
3 REPLIES 3
Message 2 of 4
Re: Contact Group
Did you try using the Contacts search facility? Once you find the contact delete it and it will be deleted from any Groups.
If you delete the contact from your Main list, which can be sorted by first or last name it will delete the contact from any Group that contains it.
Message 3 of 4
Contact Group
Thank you.  I did find the contact just by running down the list but I'm still bemused that they are listed in such disarray rather than by first of last name.  Would like them in alphabetical order...   Main contact list is in alphabetical and you can choose first or last name, but can't understand why not the groups.  Any ideas?
Message 4 of 4
Re: Contact Group
Hi there @HTSJULIE
Thanks for coming here.
I appreciate you posting about this,  there is another thread for setting up contacts in order that may help on the community here.
If you need any further support please let us know.
Leanne 🙂
